はじめに
Before you begin disassembly, be sure to have the necessary tools. You will need a Torx size T6 screwdriver, tweezers, and the device opening tool. You will be removing the stylus, the back panel, the battery, and the motherboard in order to access the LCD screen.
必要な工具と部品
この手順で使用する道具:Tweezers$4.99
Use tweezers to unplug the battery cable from the motherboard socket.
Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
Use the plastic opening tool to pry the orange clamp away from the motherboard.
Use the plastic opening tool at the bottom of the device to pry the motherboard away from the front plate.
Gently and forcefully lift the motherboard away from the front plate by using your thumb and forefinger.
Pull the LCD screen up from the bottom of the device using your forefinger.
The LCD screen will easily come away from the front panel.
2 の人々がこのガイドを完成させました。
