メインコンテンツにスキップ
Palm m105 Batteries Replacement
  1. Palm m105 Batteries Replacement, Batteries: 手順 1、 1の画像 1
    • Press the latch on the battery door on the back of the device and pull outwards.
    • Back the device up if possible, you may lose all your data if there is no power for a little too long for it to retain it, make sure this is done quickly.
  2. Palm m105 Batteries Replacement: 手順 2、 1の画像 1
    • Install two AAA alkaline batteries into the battery compartment, placing the positive and negative ends of the battery in the correct positions. (Shown as a diagram inside the battery compartment)
    • Make sure to remove one battery at a time and replace with fresh battery. This will retain information on the device.
  3. Palm m105 Batteries Replacement: 手順 3、 1の画像 1
    • Place the battery door back into place on the back of the device; it will make a 'click' sound when properly reattached.
終わりに
作成者
6人の作成者と共同で作成されました。
Erik Thompson
メンバー登録日: 10/04/11
31 ポイント
5のガイドは作成済み
チーム
UW Stout, Team 1-3, Zhou Fall 2011 UW Stout, Team 1-3, Zhou Fall 2011人のメンバー
UWSTOUT-ZHOU-F11S1G3
4 メンバー
7のガイドは作成済み
コメント 1 件
"Moderate difficulty"?? There's only three steps and two of them involve removing and reinstalling the battery door.
Gene Merritt - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 1,242
