メインコンテンツにスキップ
はじめに
This guide will provide instructions and visuals on how to replace the display screen.
パーツ
パーツは指定されていません。
  1. Remove the batteries.
    • Remove the batteries.
  2. Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  3. Remove rear cover by gently lifting it up from the bottom.
    • Remove rear cover by gently lifting it up from the bottom.
  4. Carefully lift up the circuit board, which will also lift up the screen. Do so carefully to prevent breaking the connectors.
    • Carefully lift up the circuit board, which will also lift up the screen. Do so carefully to prevent breaking the connectors.
    • Lift the left side of the circuit board and open it as though it were a book.
  5. Unplug the three connectors located on the right side of the circuit board with great caution and care. Do not pull by the cable, and be sure to pull the connector itself gently.
    • Unplug the three connectors located on the right side of the circuit board with great caution and care. Do not pull by the cable, and be sure to pull the connector itself gently.
    • After separating the screen from the board, set aside the old display screen.
    • Replace with a new display screen.
  6. Plug in the three connectors.
    • Plug in the three connectors.
  7. Close again like a book, and lay it gently into the front panel, screen facing outwards of the front panel.
    • Close again like a book, and lay it gently into the front panel, screen facing outwards of the front panel.
  8. Put the back cover on the device and screw the four screws, screwing in a clockwise direction.  Take caution not to over-tighten the screws.
    • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
まとめ
Lexi Gallucci
メンバー登録日: 2011年10月18日
11 ポイント
2のガイドは作成済み
チーム
James Madison, Team 1-3, Allen Fall 2011 James Madison, Team 1-3, Allen Fall 2011人のメンバー
JMU-ALLEN-F11S1G3
5 メンバー
5のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 535
