メインコンテンツにスキップ
Palm Zire m150 Control Button Replacement
必要な工具と部品
  1. Palm Zire m150 Control Button Replacement, Control Button: 手順 1、 2の画像 1 Palm Zire m150 Control Button Replacement, Control Button: 手順 1、 2の画像 2
    • Lift up the flap on the Palm Zire M150.
    • For the purpose of this guide and being able to see clearly, we removed the flap completely. You can keep your flap on if you wish.
    • If you wish to remove it, gently lift up on the flap and pull horizontally. It should come off without an issue.
  2. Palm Zire m150 Control Button Replacement: 手順 2、 1の画像 1
    • Take the screwdriver from the IFixit toolkit and use the T6 bit. Unscrew the the top two 3mm screws above where the flap was connected to the device.
  3. Palm Zire m150 Control Button Replacement: 手順 3、 2の画像 1 Palm Zire m150 Control Button Replacement: 手順 3、 2の画像 2
    • Gently pull the top half and bottom half off the device apart using both hands so that it looks like the second photo.
    • You can use your finger nails to pry apart the top half and the bottom half of the device. If that doesn't work, use the opening picks from the toolkit.
  4. Palm Zire m150 Control Button Replacement: 手順 4、 1の画像 1
    • This is the button that you are going to be replacing. Grab the grey button and pull it apart from the device.
    • If you are not replacing the button and you are just cleaning it, make sure you are gentle when you pull it from the device so that you don't break the button.
    • You can use compressed air to clean them or an alcohol wipe.
  5. Palm Zire m150 Control Button Replacement: 手順 5、 1の画像 1
    • The button is now off of the device. If you are cleaning it, use the compressed air or the alcohol wipe.
    • If installing a new button, throw away the one you just took off and snap the new one back on the white piece.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Kate
メンバー登録日: 01/26/16
528 ポイント
5のガイドは作成済み
チーム
USF Sarasota-Manatee, Team 1-3, Stewart Spring 2016 USF Sarasota-Manatee, Team 1-3, Stewart Spring 2016人のメンバー
USFSM-STEWART-S16S1G3
5 メンバー
7のガイドは作成済み
コメント 1 件
Kate what hairy arms you have lol
Jimfixer - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 385
