メインコンテンツにスキップ
Palm Zire 72v1 Screen Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Palm Zire 72v1 Screen Replacement, Zire 72v1: 手順 1、 1の画像 1
    • Power off your Zire 72 and turn the unit over.
    • Remove the two screws on the bottom of the rear of the unit.
    • Peel back the information sticker.
    • Remove the one screw that connects the metal panel to the body of the Zire72.
    • Use the tip of your screwdriver to pop the metal panel off the top of the rear of the unit to expose two more screws on the top corners.
  2. Palm Zire 72v1 Screen Replacement: 手順 5、 2の画像 1 Palm Zire 72v1 Screen Replacement: 手順 5、 2の画像 2
    • Remove the two top screws.
    • Insert the tip of your screwdriver in the seam where the front frame meets the body of the unit and pry the frame up to pop it off. Remove it.
  3. Palm Zire 72v1 Screen Replacement: 手順 7、 1の画像 1
    • Pull the back panel off the body of the unit to expose the motherboard in the body.
    • Unplug the two orange ribbon cables at the top of the motherboard and remove the motherboard from the body. All that is left is the LCD screen in the front housing of the unit.
  4. Palm Zire 72v1 Screen Replacement: 手順 9、 1の画像 1
    • Remove the screen from the front housing and set it aside.
    • Now that you have your Zire open, you can remove and replace the defective part.
  5. Palm Zire 72v1 Screen Replacement, Screen: 手順 11、 1の画像 1
    • Having successfully completed the Palm Zire72v1 Teardown, your device should now closely resemble this picture.
    • The front and back panels should be separated and laid side-by-side.
    • The front panel is on the left and contains the screen and navigation buttons.
    • The back panel is on the right and contains the circuit board and battery.
  6. Palm Zire 72v1 Screen Replacement: 手順 12、 1の画像 1
    • To replace the screen, you will be working exclusively with the front (left) panel.
  7. Palm Zire 72v1 Screen Replacement: 手順 13、 1の画像 1
    • Remove the old screen by sliding it upward and out of the plastic shell.
    • The navigation panel may be removed if it interferes with screen replacement.
  8. Palm Zire 72v1 Screen Replacement: 手順 14、 1の画像 1
    • Once the old screen is completely, you be left with the plastic shell.
    • The new screen will be inserted into this case.
  9. Palm Zire 72v1 Screen Replacement: 手順 15、 1の画像 1
    • The old screen will be entirely separate from the rest of the device.
    • Dispose of this broken technology responsibly.
    • You are now set to insert the new screen and reassemble the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Cherri
メンバー登録日: 09/08/11
37 ポイント
1ガイドが承認済み
コメント 1 件
A very clear process description, thank you very much.
And the disassembly process described works for battery replacement too.
But where can I find a replacement screen? One that doesn't cost the earth? And where too can I find a battery replacement?
TIA,
JC in Canberra, Australia
jthadcarroll@yahoo.com.au
jthadcarroll - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 1,309
