はじめに
Use this guide to replace a screen that is cracked or otherwise broken. Ensure that the problem can't be eliminated any other way, such as with a reset. See the Zire72v1 Troubleshooting page for other techniques to use on a faulty device.
必要な工具と部品
Having successfully completed the Palm Zire72v1 Teardown, your device should now closely resemble this picture.
The front and back panels should be separated and laid side-by-side.
The front panel is on the left and contains the screen and navigation buttons.
The back panel is on the right and contains the circuit board and battery.
ある他の人がこのガイドを完成しました。
コメント 1 件
A very clear process description, thank you very much.
And the disassembly process described works for battery replacement too.
But where can I find a replacement screen? One that doesn't cost the earth? And where too can I find a battery replacement?
TIA,
JC in Canberra, Australia
jthadcarroll@yahoo.com.au
