メインコンテンツにスキップ
Palm Vx Screen Replacement
必要な工具と部品
  1. Palm Vx Screen Replacement, Screen: 手順 1、 1の画像 1
    • Take protective cover off of organizer.
    • Note: cover slides off like pointer pen.
  2. Palm Vx Screen Replacement: 手順 2、 1の画像 1
    • Lay device face down on surface.
  3. Palm Vx Screen Replacement: 手順 3、 2の画像 1 Palm Vx Screen Replacement: 手順 3、 2の画像 2
    • Heat each side for 30 seconds individually.
    • Note: Be aware not to heat the screen, or any part to the point of damage.
    • Caution: Heating the metal case may cause burns.
  4. Palm Vx Screen Replacement: 手順 4、 3の画像 1 Palm Vx Screen Replacement: 手順 4、 3の画像 2 Palm Vx Screen Replacement: 手順 4、 3の画像 3
    • Pry off each side individually using a plastic pry bar.
    • Note: Using a plastic pry bar will keep from damaging the case. DO NOT use a metal screwdriver or similar tool.
    • Repeat for front and back of PDA.
    • Note: Do not lose the green power button that may fall out.
  5. Palm Vx Screen Replacement: 手順 5、 1の画像 1
    • Remove the screen from the plastic casing.
  6. Palm Vx Screen Replacement: 手順 6、 2の画像 1 Palm Vx Screen Replacement: 手順 6、 2の画像 2
    • In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
    • To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
    • Once the clamp is up you can use the tweezers to gently detach the ribbon.
  7. Palm Vx Screen Replacement: 手順 7、 1の画像 1
    • Now you must flip up the adjacent clamp as well, using tweezers like before.
    • After the clamp is flipped you can gently remove the second ribbon with tweezers.
  8. Palm Vx Screen Replacement: 手順 8、 1の画像 1
    • Before removing the screen you must detach one more wire, the battery connector.
    • Using the tweezers, squeeze the connector attached to the wire and genlty pull.
    • Do not pull on the wire.
  9. Palm Vx Screen Replacement: 手順 9、 2の画像 1 Palm Vx Screen Replacement: 手順 9、 2の画像 2
    • Now that both ribbons and the wire are disconeccted, you can apply a downward pressure to the battery. You will have to carefully rotate the frame so that the battery can go through.
終わりに
作成者
3人の作成者と共同で作成されました。
Will Doornink
メンバー登録日: 10/04/11
11 ポイント
1ガイドが承認済み
チーム
UW Stout, Team 5-4, Zhou Fall 2011 UW Stout, Team 5-4, Zhou Fall 2011人のメンバー
UWSTOUT-ZHOU-F11S5G4
4 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 1,913
