メインコンテンツにスキップ
Palm Treo Pro Speaker Replacement
必要な工具と部品
  1. Palm Treo Pro Speaker Replacement, Battery: 手順 1、 3の画像 1 Palm Treo Pro Speaker Replacement, Battery: 手順 1、 3の画像 2 Palm Treo Pro Speaker Replacement, Battery: 手順 1、 3の画像 3
    • Press down on the back of the case and slide forward to remove it.
  2. Palm Treo Pro Speaker Replacement: 手順 2、 1の画像 1
    • Remove the battery by pulling up on the tab near the camera lens.
    • Insert the new battery into the open slot. Make sure the battery is oriented so that the Palm logo is in the upper-left corner opposite the camera lens.
  3. Palm Treo Pro Speaker Replacement, Motherboard: 手順 3、 3の画像 1 Palm Treo Pro Speaker Replacement, Motherboard: 手順 3、 3の画像 2 Palm Treo Pro Speaker Replacement, Motherboard: 手順 3、 3の画像 3
    • Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
    • Be careful not to misplace these screws as they are very small and will be important during reassembly.
    • If the screws are stripped a flat head screw driver may be necessary.
  4. Palm Treo Pro Speaker Replacement: 手順 4、 3の画像 1 Palm Treo Pro Speaker Replacement: 手順 4、 3の画像 2 Palm Treo Pro Speaker Replacement: 手順 4、 3の画像 3
    • Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera.
  5. Palm Treo Pro Speaker Replacement: 手順 5、 3の画像 1 Palm Treo Pro Speaker Replacement: 手順 5、 3の画像 2 Palm Treo Pro Speaker Replacement: 手順 5、 3の画像 3
    • Remove the main plastic body
    • Insert the plastic opening tool into the slot on the top (indicated by the spudger) and pry the black part off phone.
    • The bottom piece around the headphone and USB port may get caught during this step. Simply carefully maneuver the case until it is released.
  6. Palm Treo Pro Speaker Replacement: 手順 6、 3の画像 1 Palm Treo Pro Speaker Replacement: 手順 6、 3の画像 2 Palm Treo Pro Speaker Replacement: 手順 6、 3の画像 3
    • Use the Philips Head 00 screwdriver to unscrew the 3.5mm silver screw on the right hand side of the phone.
    • Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard.
  7. Palm Treo Pro Speaker Replacement: 手順 7、 2の画像 1 Palm Treo Pro Speaker Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables.
  8. Palm Treo Pro Speaker Replacement: 手順 8、 3の画像 1 Palm Treo Pro Speaker Replacement: 手順 8、 3の画像 2 Palm Treo Pro Speaker Replacement: 手順 8、 3の画像 3
    • There are two ribbon cables under the yellow tape.
    • Use tweezers to safely unplug the small ribbon cable first and then the large ribbon cable.
    • To remove the cables there is a small black lock that needs to be in the up position as indicated in picture two.
  9. Palm Treo Pro Speaker Replacement: 手順 9、 3の画像 1 Palm Treo Pro Speaker Replacement: 手順 9、 3の画像 2 Palm Treo Pro Speaker Replacement: 手順 9、 3の画像 3
    • Use a plastic opening tool to lift the motherboard up and out of the phone case
    • There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
    • It can easily be disconnected with your fingers
    • Note: During this process the mute and power buttons may fall out of the phone. Do not panic this is completely normal. Set them aside in a safe place until reassembly.
    • The motherboard has now been completely removed
  10. Palm Treo Pro Speaker Replacement, Speaker: 手順 10、 1の画像 1
    • Insert your plastic pry in the gap at the top of the phone above the speaker.
  11. Palm Treo Pro Speaker Replacement: 手順 11、 3の画像 1 Palm Treo Pro Speaker Replacement: 手順 11、 3の画像 2 Palm Treo Pro Speaker Replacement: 手順 11、 3の画像 3
    • Gently pry the speaker until it comes out of its holder. This should not take a lot of force to do.
  12. Palm Treo Pro Speaker Replacement: 手順 12、 1の画像 1
    • The speaker can be gently lifted off the phone and set aside for cleaning, repair, or replacement.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
AJ Fite
メンバー登録日: 04/18/13
21 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 8-59, Johann Spring 2013 Cal Poly, Team 8-59, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S8G59
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 187
