はじめに
How to replace the keyboard on your Palm Treo Pro
必要な工具と部品
Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
Use the plastic opening tool to pry the side of the display glass up so you can easily remove it with your hand.
Locate the four tabs above the keyboard. The following steps will demonstrate how to remove the metal plate from the tabs, which will reveal the keyboard.
ある他の人がこのガイドを完成しました。
