この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Remove the keyboard in order to replace the rubber button pad, keypad, or keyboard circuit.
必要な工具と部品
Press the button on the back cover to release the battery cover.
Slide off the battery cover.
Remove the stylus by pulling up on the large top to reveal the top left case screw.
Pull away the black flap to reveal the top right case screw.
Gently peel off the protective yellow tape covering the ribbon cable using tweezers or your fingers.
Using your fingers gently lift the display screen panel out of the casing by either grasping it from the back or popping it out of the front.
Using the Phillips 00 screwdriver attachment remove the two silver, 0.121 inch long screws connecting the keypad to the casing.
