メインコンテンツにスキップ
はじめに
Replace the keyboard!!
パーツ
パーツは指定されていません。
  1. On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Use the T6 Torx Screwdriver to remove all 4 screws. You have to first remove the Stylus to  access the 4th screw.
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Apple Watch キット
    Screen and battery repairs just got easier.
    ショップを見る
    Apple Watch キット
    ショップを見る
  4. Using a plastic opening tool, carefully separate the front and back cases. Note: The antenna will detach from the phone.
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  5. Using a T6 Torx Screwdriver, remove the two screws. The motherboard will now be loose from the front case.
    • Using a T6 Torx Screwdriver, remove the two screws.
    • The motherboard will now be loose from the front case.
  6. Using the spudger, flip open the clasp that holds the data ribbon in place.
    • Using the spudger, flip open the clasp that holds the data ribbon in place.
  7. Pull out the ribbon.
    • Pull out the ribbon.
    • The keyboard will disconnect from the phone.
まとめ
Clement Poisson
メンバー登録日: 2010年01月26日
24 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 13-23, Maness Winter 2010 Cal Poly, Team 13-23, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S13G23
4 メンバー
16のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,422
