この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will walk you through the steps to remove and replace the front panel on a Palm T|X.
必要な工具と部品
Orient the device so that the display faces forward.
Remove the stylus from the right side.
Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
Orient the device sideways, as shown in the picture.
Lightly push the front of the display to separate it from the front panel.
Use a T5 Torx screwdriver to remove the 7.75mm screws at the bottom of the device.
2 の人々がこのガイドを完成させました。
