メインコンテンツにスキップ
Palm Pre Motherboard Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Palm Pre Motherboard Replacement, Antenna: 手順 1、 2の画像 1 Palm Pre Motherboard Replacement, Antenna: 手順 1、 2の画像 2
    • First the back panel must be removed to reveal the battery.
    • Remove the battery pack.
  2. Palm Pre Motherboard Replacement: 手順 2、 2の画像 1 Palm Pre Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the six T5 screws necessary to separate the backplate from the phone.
    • There is one screw in the upper right that is concealed by a small sticker labeled "Palm."
    • Additionally, there are interlocking tabs securing the back plate around the edges.
    • Use the opening tool to carefully go around the phone releasing these tabs.
  3. Palm Pre Motherboard Replacement: 手順 3、 2の画像 1 Palm Pre Motherboard Replacement: 手順 3、 2の画像 2
    • Lift the metal flap marked in red to reveal the antenna connectors.
    • Carefully pry these the antennas from their connections, this can be done quite easily.
    • Take note of which colored wire is attached to each connection. The white wire corresponds to GPS, while the black wire corresponds to DIV, or diversity antenna.
  4. Palm Pre Motherboard Replacement, PCB (Phone Circuit Board): 手順 4、 3の画像 1 Palm Pre Motherboard Replacement, PCB (Phone Circuit Board): 手順 4、 3の画像 2 Palm Pre Motherboard Replacement, PCB (Phone Circuit Board): 手順 4、 3の画像 3
    • With the backplate removed, we have easy access to the PCB.
    • Two connectors must be disconnected so that we can remove the PCB.
    • Gentle prying with the opening tool should easily separate the glued PCB from the rest of the phone.
  5. Palm Pre Motherboard Replacement, Motherboard: 手順 5、 1の画像 1
    • Once you have removed the PCB, you can proceed to removing the keyboard bezel.
    • To do this, use a spudger to gently lift off the plastic edging as shown. There are small plastic hooks attaching the bezel to the keyboard.
    • Be careful not to rip any of the loops on the keyboard.
  6. Palm Pre Motherboard Replacement: 手順 6、 3の画像 1 Palm Pre Motherboard Replacement: 手順 6、 3の画像 2 Palm Pre Motherboard Replacement: 手順 6、 3の画像 3
    • Now you are ready to pry the slider function from the back of the screen.
    • Remove the four screws. The bottom two screws are easier to see when the phone is slid about half open.
    • Again, use the spudger to pry around the edges loosening it until it comes apart.
    • There are several connectors still attaching these two pieces. Use the spudger to disconnect them on the screen.
  7. Palm Pre Motherboard Replacement: 手順 7、 2の画像 1 Palm Pre Motherboard Replacement: 手順 7、 2の画像 2
    • Next, remove four connectors to remove the mother board.
    • Use a spudger to gently pry the four connectors.
    • There is a yellow film over some of the connectors that must be removed prior to removing the connections.
    • After everything is disconnected, the mother board should lift out easily.
終わりに
作成者
7人の作成者と共同で作成されました。
iDeleted
メンバー登録日: 07/07/10
2,101 ポイント
39のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 336
