メインコンテンツにスキップ
Palm IIIx Touch Screen Replacement
必要な工具と部品
  1. Palm IIIx Touch Screen Replacement, Battery: 手順 1、 1の画像 1
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Touch Screen Replacement: 手順 2、 1の画像 1
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Touch Screen Replacement: 手順 3、 1の画像 1
    • Remove the old batteries one at a time.
  4. Palm IIIx Touch Screen Replacement, Touch Screen: 手順 4、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Touch Screen Replacement: 手順 5、 1の画像 1
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers.
  6. Palm IIIx Touch Screen Replacement: 手順 6、 1の画像 1
    • Hold the screen and front cover on its side, facing the screen inward as shown.
    • Position your hands so that you can push the screen outward with your thumbs.
    • Remove the screen by pushing outward with your thumbs. Use your index fingers to hold the front cover in place.
  7. Palm IIIx Touch Screen Replacement: 手順 7、 2の画像 1 Palm IIIx Touch Screen Replacement: 手順 7、 2の画像 2
    • Position the device with the screen facing down.
    • Locate the white ribbon wire on the left hand side of the device.
    • On either side of the ribbon wire are two white clasps. Gently push the two clasps away from the board (to the left).
  8. Palm IIIx Touch Screen Replacement: 手順 8、 1の画像 1
    • Detach the ribbon wire by gently pulling it out of its connector.
  9. Palm IIIx Touch Screen Replacement: 手順 9、 1の画像 1
    • Separate the motherboard from the screen.
  10. Palm IIIx Touch Screen Replacement: 手順 10、 2の画像 1 Palm IIIx Touch Screen Replacement: 手順 10、 2の画像 2
    • On the back of the screen near the top right corner is a plastic filament:
    • Gently lift up on the two brown clasps on either side of the filament connector as shown.
    • Using a thin, blunt object (a toothpick works well), slide it under the plastic filament and lift up to detach the filament from its connector.
  11. Palm IIIx Touch Screen Replacement: 手順 11、 1の画像 1
    • Insert a spudger tool between the metal backing and the glass cover piece, as shown.
    • Run the spudger along the edge of the screen until the screen is lifted and can be removed.
    • Replace or clean as needed.
終わりに
ある他の人がこのガイドを完成しました。
作成者
11人の作成者と共同で作成されました。
David Haskell
メンバー登録日: 01/21/10
44 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 14-43, Regan Winter 2010 Cal Poly, Team 14-43, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S14G43
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 2,401
