はじめに
Follow this guide to replace a non-working screen with a new one.
パーツ
パーツは必要ありません。
Keep track of all pieces removed from the device.
  • Keep track of all pieces removed from the device.
  • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
コメントを追加する
Using a Phillips head screw driver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
  • Using a Phillips head screw driver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
  • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
コメントを追加する
父の日に贈るギフトガイド
お父さん以外の人にも感謝の気持ちを伝えましょうー修理を教えてくれたメンターの人たちにも感謝しましょう。
父の日に贈るギフトガイド
修理を教えてくれた人たちに感謝しましょう。
Using a spudger, carefully pry open the front and back covers along the side seam.
  • Using a spudger, carefully pry open the front and back covers along the side seam.
  • A small sensor cover will fall out when the front and back covers are removed. Keep track of it.
コメントを追加する
With the device on its back, you should now be able to see the motherboard; behind it you will find a plastic clamp, the tab of a ZIF connector, pop it out and remove electric ribbon cable.
  • With the device on its back, you should now be able to see the motherboard; behind it you will find a plastic clamp, the tab of a ZIF connector, pop it out and remove electric ribbon cable.
  • The use of a prying tool is recommended.
コメントを追加する
Pop out the old screen and insert the new one.
  • Pop out the old screen and insert the new one.
  • The adhesive may create some difficulties, but the screen should come off without using much force.
コメントを追加する
まとめ
Paulina Trujillo
メンバー登録日: 2011年04月07日
241 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 20-69, Walters Spring 2011 Cal Poly, Team 20-69, Walters Spring 2011人のメンバー
CPSU-WALTERS-S11S20G69
5 メンバー
9のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,142
