はじめに
This guide will walk you through the process of replacing a bad optical drive in a Packard Bell 4x4 desktop.
必要な工具と部品
Using a Phillips screwdriver, remove the three Phillips head screws (circled in red) from the back of the computer.
Remove the two Philips head screws with your Philips screwdriver. You may have to lubricate these screws as they can be very difficult to remove.
Remove the 1 Philips head screw with your Phillips screwdriver. There should not be a screw in the right hole.
ある他の人がこのガイドを完成しました。
