メインコンテンツにスキップ
Pacific Image Electronics CS3600 Bulb Panel Replacement
必要な工具と部品
  1. Pacific Image Electronics CS3600 Bulb Panel Replacement, Bulb Panel: 手順 1、 2の画像 1 Pacific Image Electronics CS3600 Bulb Panel Replacement, Bulb Panel: 手順 1、 2の画像 2
    • Start by removing the 5 screws that are 5mm x 9mm located on the bottom of the device with a J1 screwdriver.
  2. Pacific Image Electronics CS3600 Bulb Panel Replacement: 手順 2、 1の画像 1
    • Now that the screws have been removed, carefully but firmly open up the device at the seam until it is presented as shown.
  3. Pacific Image Electronics CS3600 Bulb Panel Replacement: 手順 3、 1の画像 1
    • Use a J0 screwdriver to remove the following four screws that are 5mm x 9mm.
  4. Pacific Image Electronics CS3600 Bulb Panel Replacement: 手順 4、 1の画像 1
    • Use the same J0 screwdriver to remove the following 3 screws that are 7mm x 6mm.
  5. Pacific Image Electronics CS3600 Bulb Panel Replacement: 手順 5、 1の画像 1
    • Now grab the plastic cover you just removed screws from and gently remove it from the device.
  6. Pacific Image Electronics CS3600 Bulb Panel Replacement: 手順 6、 1の画像 1
    • You may now pick up the plastic covering you removed screws from in Step 3 with ease revealing the bulb.
  7. Pacific Image Electronics CS3600 Bulb Panel Replacement: 手順 7、 1の画像 1
    • Lodge the plastic opening tool underneath the bulb casing. Using some upward force, pop the bulb off the casing.
  8. Pacific Image Electronics CS3600 Bulb Panel Replacement: 手順 8、 1の画像 1
    • You have now removed the bulb from the casing. Gently pull the wires forward and prepare a soldering station.
  9. Pacific Image Electronics CS3600 Bulb Panel Replacement: 手順 9、 1の画像 1
    • Carefully desolder the 2 wires from their solder contact points to detach the bulb panel from the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Kristen Prince
メンバー登録日: 03/21/17
201 ポイント
2のガイドは作成済み
チーム
Texas Tech, Team S46-G2, Bennett Spring 2017 Texas Tech, Team S46-G2, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S46G2
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 16
今までの合計 330
