はじめに
If your PSP Go's logic board failed, you're in luck. Use this guide to get it fixed!
必要な工具と部品
Unscrew the four Phillips screws on the back of the PSP Go.
Rotate the PSP so you can see the top of the device.
Unscrew the two Phillips screws next to the volume buttons.
Use the plastic opening tool to gently peel away at the "Warranty Void" sticker. Start on one edge, as shown, and slide the tool from side to side until the sticker is removed from just the battery.
9 の人々がこのガイドを完成させました。
