はじめに
Use this guide to remove the PSP Go's bottom plate!
ツール
パーツ
Unscrew the four Phillips screws on the back of the PSP Go.
Rotate the PSP so you can see the top of the device.
Unscrew the two Phillips screws next to the volume buttons.
Remove the two Phillips screws holding the bottom plate.
Gently lift the bottom plate away from the device.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
