メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
PSP E1000 / E1004
not read UMD games and you haven't indication for insertion games. The problem probably is in UMD switch.
You can see the video:
パーツ
パーツは指定されていません。
ビデオの概要
  1. If you haven't indication for inserted disk the problem probably is in UMD switch. If you haven't indication for inserted disk the problem probably is in UMD switch. If you haven't indication for inserted disk the problem probably is in UMD switch.
    • If you haven't indication for inserted disk the problem probably is in UMD switch.
  2. Unhook the door metal plate and disassemble UMD door. Unhook the door metal plate and disassemble UMD door. Unhook the door metal plate and disassemble UMD door.
    • Unhook the door metal plate and disassemble UMD door.
  3. With a screwdriver I short the UMD switch to test the laser. With a screwdriver I short the UMD switch to test the laser.
    • With a screwdriver I short the UMD switch to test the laser.
  4. Now let's disassemble it. Now let's disassemble it. Now let's disassemble it.
    • Now let's disassemble it.
  5. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  6. Disconnect and remove the display. Disconnect and remove the display. Disconnect and remove the display.
    • Disconnect and remove the display.
  7. I must disconnect 7x cables and unscrew a screw. I must disconnect 7x cables and unscrew a screw.
    • I must disconnect 7x cables and unscrew a screw.
  8. Now I disconnect the battery connector and here is the mainboard. Now I disconnect the battery connector and here is the mainboard. Now I disconnect the battery connector and here is the mainboard.
    • Now I disconnect the battery connector and here is the mainboard.
  9. I used soldering station to remove the old one and put the new one (UMD switch). I used soldering station to remove the old one and put the new one (UMD switch).
    • I used soldering station to remove the old one and put the new one (UMD switch).
  10. Let's assemble and test it. Let's assemble and test it. Let's assemble and test it.
    • Let's assemble and test it.
  11. And it works!
    • And it works!
終わりに
3 の人々がこのガイドを完成させました。
ZFix
メンバー登録日: 2013年12月09日
173,928 ポイント
309のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
294 メンバー
953のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 34
過去 30 日: 122
今までの合計 7,393
