メインコンテンツにスキップ
PSP E1000 LED Driver Circuit Component Replacement
必要な工具と部品
  1. PSP E1000 LED Driver Circuit Component Replacement, Backlight electronic after water damage: 手順 1、 1の画像 1
    • this picture was made after cleaning
  2. PSP E1000 LED Driver Circuit Component Replacement: 手順 2、 2の画像 1 PSP E1000 LED Driver Circuit Component Replacement: 手順 2、 2の画像 2
    • it took me some time to find the right chip:
    • 1 - TB62752AFUG
    • 2 - Inductor 22µH/0.66A
    • 3 - MSS1P4-M3/89A
    • 4 - 2.2µF / 6,3V
    • 5 - Fuse 0.5A 0603
    • 6 - 1.0µF / 50V
    • 7 - Ferrite bead 30Ohm/3A
ゴール
11 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Steven
メンバー登録日: 05/06/14
416 ポイント
1ガイドが承認済み
7 件のコメント
Hi Steven,
Thank for your guide. It helped me restore my PSP street (in my case, the fuse was broken). But one more problem is my PSP street has no sound on speaker, but has sound on headphone. Can you give me a glue to fix?
Thank you.
Hoang Binh - 返信
I fixed it! There a broken fuse near the audio ic. Hooray!!!
Hoang Binh -
Hello Hoang Binh, I have the same problem as you, after changing the fuse to illuminate the display, no sound is heard through the speaker (only when connecting headphones, through them). Can you tell me, please, which is the fuse has been changed to solve the sound problem? An image whit the fuse be very helpful.
Olivian -
Hi @olivian. Sorry for late reply. I didn’t take any picture so I cannot point it out exactly. But you can find it yourself. Fuses often have a letter F or FB on it or its color is blue.
Hoang Binh - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 25
過去 30 日: 147
今までの合計 9,311
