メインコンテンツにスキップ
PSP 300xc Speakers Replacement
必要な工具と部品
  1. PSP 300xc Speakers Replacement, Battery: 手順 1、 2の画像 1 PSP 300xc Speakers Replacement, Battery: 手順 1、 2の画像 2
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
  2. PSP 300xc Speakers Replacement, Front Case: 手順 2、 1の画像 1
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
  3. PSP 300xc Speakers Replacement: 手順 3、 2の画像 1 PSP 300xc Speakers Replacement: 手順 3、 2の画像 2
    • Remove four Phillips screws from the back of the PSP.
  4. PSP 300xc Speakers Replacement: 手順 4、 1の画像 1
    • Remove two Phillips screws from the top of the PSP.
  5. PSP 300xc Speakers Replacement: 手順 5、 1の画像 1
    • Remove a single screw from the bottom edge of the PSP.
  6. PSP 300xc Speakers Replacement: 手順 6、 2の画像 1 PSP 300xc Speakers Replacement: 手順 6、 2の画像 2
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
  7. PSP 300xc Speakers Replacement, LCD: 手順 7、 1の画像 1
    • Remove a single Phillips screw securing the home bar to the PSP 300xc.
  8. PSP 300xc Speakers Replacement: 手順 8、 2の画像 1 PSP 300xc Speakers Replacement: 手順 8、 2の画像 2
    • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
    • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
  9. PSP 300xc Speakers Replacement: 手順 9、 1の画像 1
    • Insert a spudger under the LCD, beside the black plastic tab.
    • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
  10. PSP 300xc Speakers Replacement: 手順 10、 1の画像 1
    • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
  11. PSP 300xc Speakers Replacement: 手順 11、 3の画像 1 PSP 300xc Speakers Replacement: 手順 11、 3の画像 2 PSP 300xc Speakers Replacement: 手順 11、 3の画像 3
    • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
    • Be sure you are prying up on the retaining flap, not the socket itself
    • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
  12. PSP 300xc Speakers Replacement: 手順 12、 1の画像 1
    • Remove the LCD from the PSP 300xc.
  13. PSP 300xc Speakers Replacement, Home Bar: 手順 13、 3の画像 1 PSP 300xc Speakers Replacement, Home Bar: 手順 13、 3の画像 2 PSP 300xc Speakers Replacement, Home Bar: 手順 13、 3の画像 3
    • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
    • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
    • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
    • The home bar should now lift out of the PSP 300xc.
  14. PSP 300xc Speakers Replacement, Speakers: 手順 14、 1の画像 1
    • Using the flat end of a spudger, peel the left trigger contact pad up from the case.
  15. PSP 300xc Speakers Replacement: 手順 15、 2の画像 1 PSP 300xc Speakers Replacement: 手順 15、 2の画像 2
    • Using a fingernail or spudger, flip up the retaining bracket on the d-pad and 'L' trigger ribbon cable.
    • Lift the black plastic bracket along with the d-pad contact pad, disconnecting the ribbon cable as you lift.
  16. PSP 300xc Speakers Replacement: 手順 16、 1の画像 1
    • Pop the left speaker out from the bottom of the black plastic bracket.
    • Set the left speaker aside.
  17. PSP 300xc Speakers Replacement: 手順 17、 1の画像 1
    • Push the black tab holding the right speaker down to the left.
    • The speaker will pop out of place after pushing the tab.
    • Remove the speaker.
終わりに
作成者
2人の作成者と共同で作成されました。
Matthew Newsom
メンバー登録日: 01/05/10
39,726 ポイント
67のガイドは作成済み
コメント 1 件
How do i apply the right speaker after deconstruction?
angelsthegoat - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 1,763
