メインコンテンツにスキップ
PSP 300x Trigger Buttons Replacement
必要な工具と部品
  1. PSP 300x Trigger Buttons Replacement, Battery: 手順 1、 3の画像 1 PSP 300x Trigger Buttons Replacement, Battery: 手順 1、 3の画像 2 PSP 300x Trigger Buttons Replacement, Battery: 手順 1、 3の画像 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x Trigger Buttons Replacement, Casing: 手順 2、 1の画像 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  3. PSP 300x Trigger Buttons Replacement: 手順 3、 2の画像 1 PSP 300x Trigger Buttons Replacement: 手順 3、 2の画像 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x Trigger Buttons Replacement: 手順 4、 1の画像 1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x Trigger Buttons Replacement: 手順 5、 1の画像 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. PSP 300x Trigger Buttons Replacement: 手順 6、 2の画像 1 PSP 300x Trigger Buttons Replacement: 手順 6、 2の画像 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
  7. PSP 300x Trigger Buttons Replacement, LCD Screen: 手順 7、 2の画像 1 PSP 300x Trigger Buttons Replacement, LCD Screen: 手順 7、 2の画像 2
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
  8. PSP 300x Trigger Buttons Replacement: 手順 8、 3の画像 1 PSP 300x Trigger Buttons Replacement: 手順 8、 3の画像 2 PSP 300x Trigger Buttons Replacement: 手順 8、 3の画像 3
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
  9. PSP 300x Trigger Buttons Replacement: 手順 9、 2の画像 1 PSP 300x Trigger Buttons Replacement: 手順 9、 2の画像 2
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
  10. PSP 300x Trigger Buttons Replacement: 手順 10、 1の画像 1
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
  11. PSP 300x Trigger Buttons Replacement, Trigger Buttons: 手順 11、 1の画像 1
    • Remove the screw securing 'L' trigger to the PSP.
  12. PSP 300x Trigger Buttons Replacement: 手順 12、 1の画像 1
    • Remove the white plastic piece that holds the 'L' trigger in place.
  13. PSP 300x Trigger Buttons Replacement: 手順 13、 1の画像 1
    • Remove the 'L' trigger from the PSP.
  14. PSP 300x Trigger Buttons Replacement: 手順 14、 1の画像 1
    • Remove the screw securing the 'R' trigger.
  15. PSP 300x Trigger Buttons Replacement: 手順 15、 1の画像 1
    • Remove the white plastic piece that holds the 'R' trigger in place.
  16. PSP 300x Trigger Buttons Replacement: 手順 16、 1の画像 1
    • Remove the 'R' trigger from the PSP.
終わりに
11 の人々がこのガイドを完成させました。
作成者
13人の作成者と共同で作成されました。
cmcevill
メンバー登録日: 11/05/09
517 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 19-2, Maness Fall 2009 Cal Poly, Team 19-2, Maness Fall 2009人のメンバー
CPSU-MANESS-F09S19G2
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 43
過去 30 日: 173
今までの合計 18,533
