はじめに
Steps for removing the motherboard of a Sony PSP-3000
必要な工具と部品
Place the PSP face down and locate the battery cover on the left side of the device.
Lift and remove the battery cover to reveal the battery.
Remove the battery.
Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
Push the homebar to the right to release the tab located on the right side of the LCD screen.
The speaker is spring loaded, so be sure to keep an eye on it in case it starts doing flips into the air when you push the tab. Be careful not to lose or damage it!
Remove the cable carefully by lifting upwards from port attached to the motherboard .
15 の人々がこのガイドを完成させました。
