メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
アーカイブ済み
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
アーカイブ済み
はじめに
How to change / replace joystick (analog stick).
パーツ
パーツは指定されていません。
ビデオの概要
  1. Remove the battery and memory card! Remove the battery and memory card! Remove the battery and memory card!
    • Remove the battery and memory card!
  2. You have to remove seven screws. You have to remove seven screws. You have to remove seven screws.
    • You have to remove seven screws.
  3. The front face-plate. The front face-plate.
    • The front face-plate.
  4. The plate with volume-start-home key flex. The plate with volume-start-home key flex. The plate with volume-start-home key flex.
    • The plate with volume-start-home key flex.
  5. Be careful while removing the screen! Release the cables for screen and "volume-start-home keys"! Be careful while removing the screen! Release the cables for screen and "volume-start-home keys"! Be careful while removing the screen! Release the cables for screen and "volume-start-home keys"!
    • Be careful while removing the screen! Release the cables for screen and "volume-start-home keys"!
  6. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  7. Slightly lift the board and remove the joystick! Slightly lift the board and remove the joystick!
    • Slightly lift the board and remove the joystick!
  8. Now is the time for the new replacement part. Now is the time for the new replacement part.
    • Now is the time for the new replacement part.
  9. The assembling now is easy. The assembling now is easy. The assembling now is easy.
    • The assembling now is easy.
  10. That's all. I hope I've been helpful.
    • That's all. I hope I've been helpful.
終わりに
3 の人々がこのガイドを完成させました。
ZFix
メンバー登録日: 2013年12月09日
177,254 ポイント
317のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
295 メンバー
974のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 3,922
