メインコンテンツにスキップ
PDP Victrix Pro BFG Headphone Jack Replacement
必要な工具と部品
  1. PDP Victrix Pro BFG Headphone Jack Replacement, Headphone Jack: 手順 1、 1の画像 1
    • Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
    • Remove the joystick/button modules from the controller.
  2. PDP Victrix Pro BFG Headphone Jack Replacement: 手順 2、 1の画像 1
    • Remove the two screws from the module compartments.
  3. PDP Victrix Pro BFG Headphone Jack Replacement: 手順 3、 2の画像 1 PDP Victrix Pro BFG Headphone Jack Replacement: 手順 3、 2の画像 2
    • Using the iFixit opening tool, gently pry open the two side grips.
    • Using the screwdriver tool with a head of around 2 mm, remove the screws located in the bottom outside corners.
  4. PDP Victrix Pro BFG Headphone Jack Replacement: 手順 4、 1の画像 1
    • Flip the controller to the other side so the label on the bottom is facing upwards.
    • On the label, there is a circular icon; this shows the location of a single screw.
    • Using the same screwdriver head setting from the previous step, remove the screw.
  5. PDP Victrix Pro BFG Headphone Jack Replacement: 手順 5、 1の画像 1
    • Flip the controller so the charging port of the controller is facing you.
    • Using a spudger, carefully pry open the front component.
  6. PDP Victrix Pro BFG Headphone Jack Replacement: 手順 6、 1の画像 1
    • Flip the controller so it is upside-down, but the charging port is still facing you.
    • In the center of the now exposed part, there will be a hidden silver screw.
    • Use the flexible piece attached to the screwdriver to remove this screw.
    • Now that everything is loosened, gently pry open the controller along the grooves.
  7. PDP Victrix Pro BFG Headphone Jack Replacement: 手順 7、 1の画像 1
    • Using the screwdriver tool with a smaller head, remove the three screws from each trigger.
    • Remove the triggers.
  8. PDP Victrix Pro BFG Headphone Jack Replacement: 手順 8、 1の画像 1
    • Using the screwdriver, remove the two screws in the bottom two corners.
    • Using the halberd spudger, carefully pry the circuit board open.
  9. PDP Victrix Pro BFG Headphone Jack Replacement: 手順 9、 1の画像 1
    • Using a soldering iron, desolder the headphone jack and resolder a new one in its place.
終わりに
作成者
1人の作成者と共同作成されました。
Ryan Brise
メンバー登録日: 03/20/24
169 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 1-1, Santin Spring 2024 UMass Dartmouth, Team 1-1, Santin Spring 2024人のメンバー
UMASSD-SANTIN-S24S1G1
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 25
今までの合計 46
