メインコンテンツにスキップ
PDP Victrix Pro BFG Battery and Trigger Replacement
必要な工具と部品
  1. PDP Victrix Pro BFG Battery and Trigger Replacement, Battery and Trigger: 手順 1、 1の画像 1
    • Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
    • Remove the joystick/button modules from the controller.
  2. PDP Victrix Pro BFG Battery and Trigger Replacement: 手順 2、 1の画像 1
    • Remove the screws from each of the module compartments using a PH0 or J1 bit.
  3. PDP Victrix Pro BFG Battery and Trigger Replacement: 手順 3、 2の画像 1 PDP Victrix Pro BFG Battery and Trigger Replacement: 手順 3、 2の画像 2
    • Using the iFixit opening tool, gently pry open the two side grips.
    • Using a PH0 or J1 screwdriver bit with a 4mm diameter or less, remove the screws located in the bottom outside corners.
  4. PDP Victrix Pro BFG Battery and Trigger Replacement: 手順 4、 1の画像 1
    • Flip the controller to the other side so the label on the bottom is facing upwards.
    • On the label, there is a circular icon; this shows the location of a single screw.
    • Using the same PH0 or J1 screwdriver bit from the previous steps, remove the screw.
  5. PDP Victrix Pro BFG Battery and Trigger Replacement: 手順 5、 1の画像 1
    • Flip the controller so the charging port of the controller is facing you.
    • Using a spudger, carefully pry open the front component.
  6. PDP Victrix Pro BFG Battery and Trigger Replacement: 手順 6、 1の画像 1
    • Flip the controller so it is upside-down, but the charging port is still facing you.
    • In the center of the now exposed part, there will be a hidden silver screw.
    • Use the flexible piece attached to the screwdriver to remove this screw.
    • Now that everything is loosened, gently pry open the controller along the grooves.
  7. PDP Victrix Pro BFG Battery and Trigger Replacement: 手順 7、 1の画像 1
    • Using the screwdriver tool with a smaller head, remove the three screws from each trigger.
    • Remove the triggers.
  8. PDP Victrix Pro BFG Battery and Trigger Replacement: 手順 8、 1の画像 1
    • Using the screwdriver, remove the two screws in the bottom two corners.
    • Using the halberd spudger, carefully pry the circuit board open.
  9. PDP Victrix Pro BFG Battery and Trigger Replacement: 手順 9、 1の画像 1
    • To remove the batteries, use a pair of tweezers to carefully unplug the batteries from the circuit board.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
ryanmorabito
メンバー登録日: 03/20/24
260 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 1-1, Santin Spring 2024 UMass Dartmouth, Team 1-1, Santin Spring 2024人のメンバー
UMASSD-SANTIN-S24S1G1
3 メンバー
3のガイドは作成済み
4件のガイドコメント
Only guide I could find to get this controller apart for my son. Now have to find someone to resolder the USB c port.
Matthew Lash - 返信
R2 and L2 no response, the board location for button?
Terry - 返信
if my remote doesn’t turn on or charge should I change the battery or just throw it away?
Nerdy mom - 返信
How much and how can I buy the battery's?
Dino - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 77
過去 30 日: 278
今までの合計 4,891
