はじめに
The Joystick is an essential part of the PDP Rematch controller. Over time, the joysticks may stop working due to wear and tear. If they need replacing, you can buy them separately.
必要な工具と部品
Grip one side of the controller firmly.
Insert an opening pick into the crease between the faceplate and the body of the controller.
Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
Carefully move the picks along the controller's crease line until you hear a popping sound.
Gently lift off the faceplate by hand.
ある他の人がこのガイドを完成しました。
