メインコンテンツにスキップ
PDP Afterglow Wired Xbox 360 Controller Cable Replacement
必要な工具と部品
  1. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: 手順 1、 2の画像 1 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: 手順 1、 2の画像 2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 手順 2、 1の画像 1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 手順 3、 1の画像 1
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: 手順 4、 2の画像 1 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: 手順 4、 2の画像 2
    • Remove the logic board by lifting up on the logic board and pulling out.
  5. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 手順 5、 1の画像 1
    • The cable connects to the logic board with a white connector. Above the right joystick, there are four solder pins labeled GND, VCC, DM, and DP.
  6. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 手順 6、 1の画像 1
    • The soldering iron is very hot and can harm you or the device if used incorrectly.
    • Desolder the four pins.
  7. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 手順 7、 1の画像 1
    • Using your new cable, solder the white connector to the logic board. Be sure to have the cables facing towards the inside of the logic board.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jayson Norcross
メンバー登録日: 09/17/15
283 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S3G1
4 メンバー
5のガイドは作成済み
4 件のコメント
where can I find a replacement cable to perform this precedure with?
Aaron English - 返信
yes!! i would like to know too.. i have been searching for long time for that cable
sokratis162 -
Android cable
Wayne -
U can use a old Android cable
Wayne - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 50
今までの合計 7,412
