メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide will provide step-by-step instructions for replacing the A, B, X, and Y buttons on the controller.
  1. Loosen the seven 11 mm Phillips #0 screws located on the back of the controller. Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. Using a plastic opening tool, pry the back cover from the front.
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the top cover from the bottom and place next to each other.
    • Remove the top cover from the bottom and place next to each other.
  5. Remove the rubber button covers from the A, B, X, and Y buttons.
    • Remove the rubber button covers from the A, B, X, and Y buttons.
  6. Push up on the buttons from the front and pull them out from the back. Push up on the buttons from the front and pull them out from the back.
    • Push up on the buttons from the front and pull them out from the back.
終わりに
ある他の人がこのガイドを完成しました。
Joi Officer
メンバー登録日: 2015年09月17日
247 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S3G1
4 メンバー
5のガイドは作成済み
2 件のコメント
What about removing the Dpad? i really need help.
Elijah Douglas - 返信
I’m sorry but, I have to say that the reassembly process is harder than simply ‘follow the instructions in reverse’; if you try and place the half with the buttons, the buttons fall out or end up misaligned ; and if you use the other half, the rubber covers and the tumblers will fall out.
Again, this guild comes off a little too simple, there’s more to it.
Christopher Mali-Martinez - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 40
今までの合計 2,839
