必要な工具と部品
Unscrew the two screws circled in red.
Slide the plate in the direction of the arrow.
Unscrew the screw circled in red.
Lift the disk with the green tab.
Remove the disk in the direction of the arrow.
Disconnect the two connectors circled in green.
Remove the WLAN card.
Unscrew the four large screws circled in green
Unscrew the five small screws circled in red
Lift the cooler with the two tabs circled in blue
Lift the flap that holds the two connectors framed in red.
Disconnect the two framed connectors in red.
To reassemble your device, follow the instructions in reverse order.
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
