メインコンテンツにスキップ
Ozeri Pronto ZK14-S LCD Replacement
必要な工具と部品
  1. Ozeri Pronto ZK14-S LCD Replacement, Panel Removal: 手順 1、 2の画像 1 Ozeri Pronto ZK14-S LCD Replacement, Panel Removal: 手順 1、 2の画像 2
    • Twist the plastic plate slowly to the left to pull it away.
  2. Ozeri Pronto ZK14-S LCD Replacement: 手順 2、 1の画像 1
    • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
    • The sticker does not need to be completely removed.
  3. Ozeri Pronto ZK14-S LCD Replacement: 手順 3、 1の画像 1
    • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
  4. Ozeri Pronto ZK14-S LCD Replacement: 手順 4、 2の画像 1 Ozeri Pronto ZK14-S LCD Replacement: 手順 4、 2の画像 2
    • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
  5. Ozeri Pronto ZK14-S LCD Replacement: 手順 5、 2の画像 1 Ozeri Pronto ZK14-S LCD Replacement: 手順 5、 2の画像 2
    • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
  6. Ozeri Pronto ZK14-S LCD Replacement: 手順 6、 1の画像 1
    • Turn the device over so the back panel is facing up.
  7. Ozeri Pronto ZK14-S LCD Replacement: 手順 7、 1の画像 1
    • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
  8. Ozeri Pronto ZK14-S LCD Replacement: 手順 8、 1の画像 1
    • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
  9. Ozeri Pronto ZK14-S LCD Replacement: 手順 9、 2の画像 1 Ozeri Pronto ZK14-S LCD Replacement: 手順 9、 2の画像 2
    • Pry apart the two panels to separate them from each other.
    • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
    • Be careful when separating the panels to avoid damaging the wires they are connected by.
  10. Ozeri Pronto ZK14-S LCD Replacement, LCD: 手順 10、 2の画像 1 Ozeri Pronto ZK14-S LCD Replacement, LCD: 手順 10、 2の画像 2
    この手順で使用する道具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    購入する
    • Using the 2.0 Flathead screwdriver, remove the three 7.20 mm screw on the back of the center LCD motherboard.
  11. Ozeri Pronto ZK14-S LCD Replacement: 手順 11、 3の画像 1 Ozeri Pronto ZK14-S LCD Replacement: 手順 11、 3の画像 2 Ozeri Pronto ZK14-S LCD Replacement: 手順 11、 3の画像 3
    • Stand the center motherboard up to expose the LCD screen
    • Be careful when standing up the LCD motherboard to avoid damaging the wires it is connected to.
    • Remove the LCD screen.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Oneika White
メンバー登録日: 10/01/15
709 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 1-4, Leahy Fall 2015 USF Tampa, Team 1-4, Leahy Fall 2015人のメンバー
USFT-LEAHY-F15S1G4
4 メンバー
5のガイドは作成済み
コメント 1 件
I had a similar model, it was different to open but the LCD was showing all 8's, I just reset the same LCD and it worked like new.
Dennis Lima - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 9
今までの合計 554
