メインコンテンツにスキップ
Ozeri Pronto ZK14-S Panel Removal Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Ozeri Pronto ZK14-S  Panel Removal  Replacement, Panel Removal: 手順 1、 2の画像 1 Ozeri Pronto ZK14-S  Panel Removal  Replacement, Panel Removal: 手順 1、 2の画像 2
    • Twist the plastic plate slowly to the left to pull it away.
  2. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 手順 2、 1の画像 1
    • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
    • The sticker does not need to be completely removed.
  3. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 手順 3、 1の画像 1
    • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
  4. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 手順 4、 2の画像 1 Ozeri Pronto ZK14-S  Panel Removal  Replacement: 手順 4、 2の画像 2
    • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
  5. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 手順 5、 2の画像 1 Ozeri Pronto ZK14-S  Panel Removal  Replacement: 手順 5、 2の画像 2
    • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
  6. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 手順 6、 1の画像 1
    • Turn the device over so the back panel is facing up.
  7. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 手順 7、 1の画像 1
    • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
  8. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 手順 8、 1の画像 1
    • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
  9. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 手順 9、 2の画像 1 Ozeri Pronto ZK14-S  Panel Removal  Replacement: 手順 9、 2の画像 2
    • Pry apart the two panels to separate them from each other.
    • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
    • Be careful when separating the panels to avoid damaging the wires they are connected by.
終わりに
作成者
6人の作成者と共同で作成されました。
AshleyKreisel
メンバー登録日: 10/01/15
101 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-4, Leahy Fall 2015 USF Tampa, Team 1-4, Leahy Fall 2015人のメンバー
USFT-LEAHY-F15S1G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 61
