はじめに
Hello you wonderful ladies and gentlemen. Today we are going to be doing a simple battery replacement for a Overhead Door Remote. This is an easy repair and great if you are just starting out.
必要な工具と部品
Insert your screwdriver into the plastic tab, then pull up.
Now go to the bottom near where it says Overhead Door and pull up, it should pop up. Once that is open push forward and the top should release
Take your screwdriver and push it into the bottom left corner of the board as shown on the picture. Once you have it in their good, pull up lightly, the board should come up and out.
Flip the board over, you should see the battery. Take your screwdriver and push the battery out gently.
Now that the old battery is out. Put the new one in, Words up.
Now flip the board over and put it in it’s case. You should feel a light click. Remember not to be too hard.
When you got the board on, simply take the top part, be mindful of the rubber, and snap it on, the top first then the bottom. You can use the pictures above if you don’t know where it is
There you go! A fully functioning remote. Give yourself a pat on the back and go get a drink of water.
