はじめに
We will be taking apart and looking at the components of the cordless Ovente Electric Kettle.
必要な工具と部品
Remove the three 11 mm screws from the center of the kettle's base using a Phillips #2 screwdriver.
Remove the one 15mm screw by the handle using a Phillips #2 screwdriver.
Unscrew the bottom chip and take it out of the handle. Use a #1 Phillips screwdriver to take out the 8.2 mm screw.
Then, weave it out the wires that were connected to the heating element and the thermal cutoff assembly through the handle base.
Remove the chip and it's soldered wires from the handle completely.
ある他の人がこのガイドを完成しました。
1件のガイドコメント
Ugh, my Ovente KP72W (Intertek 4005297) kettle does not have any external screws on the bottom side or anywhere on the kettle. I was able to take apart the base that has 2 security screws but no issues there. The kettle does not turn on unless I smack it few times. I just smacked it against the counter with the handle side, and it came apart. The handle is just clipped on so I'm assuming that this is the same with the bottom, I'll try to take it apart when the kinetic method fails.
We really need to get back to fixable technology... at least for the sake of the environment. Hack the planet!
