メインコンテンツにスキップ
Oven Heating Element Replacement
必要な工具と部品
  1. Oven Heating Element Replacement, Element: 手順 1、 1の画像 1
    • Before purchasing your replacement element, make sure it matches the size of the first element.
    • The element may not fit inside the stove if it is not the appropriate size.
  2. Oven Heating Element Replacement: 手順 2、 2の画像 1 Oven Heating Element Replacement: 手順 2、 2の画像 2
    • Go to your electrical panel and turn off the power to the stove.
    • WARNING: Do NOT attempt any of these next steps with the power on.
  3. Oven Heating Element Replacement: 手順 3、 2の画像 1 Oven Heating Element Replacement: 手順 3、 2の画像 2
    • Open the oven door and unscrew the 5 mm Robertson head screws that keep the element in place.
    • In most cases, there will be two or three screws to remove.
    • Make sure you check the screws thoroughly in case there are more.
  4. Oven Heating Element Replacement: 手順 4、 3の画像 1 Oven Heating Element Replacement: 手順 4、 3の画像 2 Oven Heating Element Replacement: 手順 4、 3の画像 3
    • Using your voltmeter, place it on the two wires to make sure there is no electrical current.
    • Gently pull out the element two or three inches to expose the connecting wires.
  5. Oven Heating Element Replacement: 手順 5、 3の画像 1 Oven Heating Element Replacement: 手順 5、 3の画像 2 Oven Heating Element Replacement: 手順 5、 3の画像 3
    • Mark down the coloured wires and how they are connected. You will need to match them by color when you reconnect the element.
    • It may be helpful to take a photo of the element with the wires still connected. This will make reconnecting it easier.
    • Remove the screws holding the wires in place.
  6. Oven Heating Element Replacement: 手順 6、 1の画像 1
    • Remove the damaged element from the stove. It should slide out easily.
    • If possible, try to locate where the damage on the element took place for future reference.
    • Begin installing the new element.
  7. Oven Heating Element Replacement: 手順 7、 2の画像 1 Oven Heating Element Replacement: 手順 7、 2の画像 2
    • Connect the power wires by matching the same color as the original element. (Refer to Step 5 for more information.)
    • Gently re-insert the element back into the stove opening.
    • Refasten the two screws at the front to secure the element in place.
  8. Oven Heating Element Replacement: 手順 8、 1の画像 1
    • Close the oven door and reset the power through the electrical panel.
  9. Oven Heating Element Replacement: 手順 9、 1の画像 1
    • Turn the power on and turn the oven on to make sure the element is functioning properly.
    • There may be some smoke and an odor coming from the baking element because of the protective coating. This is normal.
ゴール
作成者
1人の作成者と共同作成されました。
Alex Costantino
メンバー登録日: 01/15/21
199 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G2, Woodhouse Winter 2021 York University, Team S1-G2, Woodhouse Winter 2021人のメンバー
YORK-WOODHOUSE-W21S1G2
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 41
過去 30 日: 124
今までの合計 1,308
