メインコンテンツにスキップ
Ovation Acoustic Guitar String Replacement
必要な工具と部品
  1. Ovation Acoustic Guitar String Replacement, Guitar String: 手順 1、 1の画像 1
    • Place the guitar neck where you can easily identify the broken string.
  2. Ovation Acoustic Guitar String Replacement: 手順 2、 2の画像 1 Ovation Acoustic Guitar String Replacement: 手順 2、 2の画像 2
    • Place the guitar neck on an elevated surface (ex. bundle towels, pillow, etc.). Remove the string with a string winder until it is loose enough to pull out by hand.
  3. Ovation Acoustic Guitar String Replacement: 手順 3、 1の画像 1
    • Take the string out carefully and begin to pull the string out through the bridge which is at the lower end of the guitar.
  4. Ovation Acoustic Guitar String Replacement: 手順 4、 2の画像 1 Ovation Acoustic Guitar String Replacement: 手順 4、 2の画像 2
    • Once the string is removed, wipe down the guitar neck to prevent further oil buildup.
  5. Ovation Acoustic Guitar String Replacement: 手順 5、 1の画像 1
    • Layout the new guitar strings from biggest to smallest.
  6. Ovation Acoustic Guitar String Replacement: 手順 6、 3の画像 1 Ovation Acoustic Guitar String Replacement: 手順 6、 3の画像 2 Ovation Acoustic Guitar String Replacement: 手順 6、 3の画像 3
    • Pull the new string through the bridge until the stopper is flushed with the bridge.
  7. Ovation Acoustic Guitar String Replacement: 手順 7、 2の画像 1 Ovation Acoustic Guitar String Replacement: 手順 7、 2の画像 2
    • Position the skinny side of the string into the tuning peg. Allow enough excess string ( about 3 inches) so when the string is tightened, it will not break from being too tight or break from being too loose.
  8. Ovation Acoustic Guitar String Replacement: 手順 8、 3の画像 1 Ovation Acoustic Guitar String Replacement: 手順 8、 3の画像 2 Ovation Acoustic Guitar String Replacement: 手順 8、 3の画像 3
    • Loop the excess guitar string around the tuning peg and make sure the coil is being tuned downwards.
  9. Ovation Acoustic Guitar String Replacement: 手順 9、 2の画像 1 Ovation Acoustic Guitar String Replacement: 手順 9、 2の画像 2
    • Trim the excess string with pliers. Make sure it is cut as close to the tuning peg so it does not stick out.
ゴール
作成者
3人の作成者と共同で作成されました。
Rachel Galvan
メンバー登録日: 04/07/21
169 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team S1-G6, Harris Fall 2021 CSU Los Angeles, Team S1-G6, Harris Fall 2021人のメンバー
CSULA-HARRIS-F21S1G6
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 20
今までの合計 590
