メインコンテンツにスキップ
Oster Blend-N-Go My Blend Drinking Lid Seal Replacement
必要な工具と部品
  1. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Blender Bottle: 手順 1、 2の画像 1 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Blender Bottle: 手順 1、 2の画像 2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 手順 2、 3の画像 1 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 手順 2、 3の画像 2 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 手順 2、 3の画像 3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Drinking Lid Assembly: 手順 3、 1の画像 1
    • After removing the blade assembly from the blender bottle, ensure that your drinking lid assembly has its seal placed in the seal bed.
  4. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 手順 4、 3の画像 1 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 手順 4、 3の画像 2 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 手順 4、 3の画像 3
    • Grab the blender bottle with one hand and the drinking lid assembly with the other.
    • Place the drinking lid assembly onto the blender bottle and twist it clockwise until it is tight around the blender bottle.
  5. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Drinking Lid Seal: 手順 5、 1の画像 1
    • After separating the drinking lid assembly from the blender bottle, position the plastic opening tool on either side of the seal in the drinking lid assembly.
    • Wedge the tool between seal and seal seat wall.
  6. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 手順 6、 2の画像 1 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 手順 6、 2の画像 2
    • Gently pry the seal up while lifting seal out of the seal seat.
  7. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 手順 7、 2の画像 1 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 手順 7、 2の画像 2
    • Press new seal into seal seat with finger.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Paul Long
メンバー登録日: 08/27/15
710 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 12-6, Blackwell Fall 2015 USF Tampa, Team 12-6, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S12G6
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 10
今までの合計 837
