メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
Use this guide to replace a faulty drinking lid assembly.
  1. Grip the blender base with one hand and blender bottle with the other hand. Rotate the blender bottle a quarter turn counterclockwise .
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Grip the blade assembly with one hand and blender bottle with the other hand. Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle. Lift the blender bottle to separate it from the blade assembly.
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. iPhone LCDスクリーン修理キット
    生涯保証付きの低コストオプション
    キット商品を見る
    品質ではなく、修理コストを削減しましょう。
    キット商品を見る
  4. After removing the blade assembly from the blender bottle, ensure that your drinking lid assembly has its seal placed in the seal bed.
    • After removing the blade assembly from the blender bottle, ensure that your drinking lid assembly has its seal placed in the seal bed.
  5. Grab the blender bottle with one hand and the drinking lid assembly with the other. Place the drinking lid assembly onto the blender bottle and twist it clockwise until it is tight around the blender bottle. Place the drinking lid assembly onto the blender bottle and twist it clockwise until it is tight around the blender bottle.
    • Grab the blender bottle with one hand and the drinking lid assembly with the other.
    • Place the drinking lid assembly onto the blender bottle and twist it clockwise until it is tight around the blender bottle.
終わりに
ある他の人がこのガイドを完成しました。
Walter Hernandez
メンバー登録日: 2015年09月01日
238 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 12-6, Blackwell Fall 2015 USF Tampa, Team 12-6, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S12G6
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 205
