はじめに
This guide will show you how to replace the blades on an Oster 8-Speed Blender model BLSTMG-B00-33A.
Before starting this guide, ensure that your replacement blades are compatible with the Oster 8-Speed Blender model BLSTMG-B00-33A. Be sure to complete this repair on a flat and clean surface.
You might need to replace your blender’s blades if they are dull, damaged, or chipped.
Be sure to safely dispose of the old blades. Be careful when handling the blender blades because they are sharp and can cut you.
必要な工具と部品
ある他の人がこのガイドを完成しました。
