メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Oster 6329 Lever Catch Spring Replacement
必要な工具と部品
  1. Oster 6329 Lever Catch Spring Replacement, Outer Shell Removal: 手順 1、 2の画像 1 Oster 6329 Lever Catch Spring Replacement, Outer Shell Removal: 手順 1、 2の画像 2
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Lever Catch Spring Replacement: 手順 2、 1の画像 1
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Oster 6329 Lever Catch Spring Replacement: 手順 3、 1の画像 1
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Lever Catch Spring Replacement: 手順 4、 2の画像 1 Oster 6329 Lever Catch Spring Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Lever Catch Spring Replacement: 手順 5、 2の画像 1 Oster 6329 Lever Catch Spring Replacement: 手順 5、 2の画像 2
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
  6. Oster 6329 Lever Catch Spring Replacement, Lever Catch Spring: 手順 6、 1の画像 1
    この手順で使用する道具:
    • Insert the tweezers between the spring and the bottom of the lever to release the spring.
  7. Oster 6329 Lever Catch Spring Replacement: 手順 7、 2の画像 1 Oster 6329 Lever Catch Spring Replacement: 手順 7、 2の画像 2
    • Remove spring from the bottom of the lever.
    • The spring should only be connected to the top of the toaster after this is complete.
  8. Oster 6329 Lever Catch Spring Replacement: 手順 8、 1の画像 1
    • Insert the tweezers between the two metal flaps located at the top of the toaster.
    • Hold the spring and turn it sideways to lay it flat along the top of the toaster.
    • Pry the spring from the top of the toaster.
終わりに
作成者
7人の作成者と共同で作成されました。
Blaine Oelkers
メンバー登録日: 01/24/14
131 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 13-15, Regan Winter 2014 Cal Poly, Team 13-15, Regan Winter 2014人のメンバー
CPSU-REGAN-W14S13G15
5 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 37
今までの合計 1,392
