はじめに
Replacing the spring can be somewhat difficult, so be prepared to deal with a little frustration when removing the spring.
必要な工具と部品
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
この手順で使用する道具:Tweezers$4.99
Insert the tweezers between the spring and the bottom of the lever to release the spring.
