メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Oster 6329 Bread Grabber Spring Replacement
必要な工具と部品
  1. Oster 6329 Bread Grabber Spring Replacement, Outer Shell Removal: 手順 1、 2の画像 1 Oster 6329 Bread Grabber Spring Replacement, Outer Shell Removal: 手順 1、 2の画像 2
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Bread Grabber Spring Replacement: 手順 2、 1の画像 1
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Oster 6329 Bread Grabber Spring Replacement: 手順 3、 1の画像 1
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Bread Grabber Spring Replacement: 手順 4、 2の画像 1 Oster 6329 Bread Grabber Spring Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Bread Grabber Spring Replacement: 手順 5、 2の画像 1 Oster 6329 Bread Grabber Spring Replacement: 手順 5、 2の画像 2
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
  6. Oster 6329 Bread Grabber Spring Replacement, Bread Grabber Spring: 手順 6、 1の画像 1
    • Press down on the toaster handle to access to the grabber spring located behind the large metal plate.
  7. Oster 6329 Bread Grabber Spring Replacement: 手順 7、 1の画像 1
    • Locate the grabber spring.
  8. Oster 6329 Bread Grabber Spring Replacement: 手順 8、 1の画像 1
    • Use the large needle nose pliers to unwind the grabber spring from one side of the carriage to remove.
    • Repeat this step for the opposite side.
  9. Oster 6329 Bread Grabber Spring Replacement: 手順 9、 1の画像 1
    • Remove the old spring from the toaster unit to insert new.
終わりに
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Isaac Williams
メンバー登録日: 01/24/14
237 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 13-15, Regan Winter 2014 Cal Poly, Team 13-15, Regan Winter 2014人のメンバー
CPSU-REGAN-W14S13G15
5 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 23
今までの合計 1,144
