メインコンテンツにスキップ
Osmo Mobile Charging Port Replacement
必要な工具と部品
  1. Osmo Mobile Charging Port Replacement, Osmo Mobile Handle Disassembly: 手順 1、 2の画像 1 Osmo Mobile Charging Port Replacement, Osmo Mobile Handle Disassembly: 手順 1、 2の画像 2
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
  2. Osmo Mobile Charging Port Replacement: 手順 2、 2の画像 1 Osmo Mobile Charging Port Replacement: 手順 2、 2の画像 2
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
  3. Osmo Mobile Charging Port Replacement: 手順 3、 1の画像 1
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
  4. Osmo Mobile Charging Port Replacement: 手順 4、 2の画像 1 Osmo Mobile Charging Port Replacement: 手順 4、 2の画像 2
    • Remove joystick by gently pulling away from handle
  5. Osmo Mobile Charging Port Replacement: 手順 5、 3の画像 1 Osmo Mobile Charging Port Replacement: 手順 5、 3の画像 2 Osmo Mobile Charging Port Replacement: 手順 5、 3の画像 3
    この手順で使用する道具:
    購入する
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
  6. Osmo Mobile Charging Port Replacement: 手順 6、 3の画像 1 Osmo Mobile Charging Port Replacement: 手順 6、 3の画像 2 Osmo Mobile Charging Port Replacement: 手順 6、 3の画像 3
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
  7. Osmo Mobile Charging Port Replacement, Charging Port: 手順 7、 1の画像 1
    • Remove the top left screw on the joystick panel with Phillips #00 screwdriver.
    • Lift faceplate holding joystick module.
  8. Osmo Mobile Charging Port Replacement: 手順 8、 1の画像 1
    • Remove the bottom right screw on the joystick panel with the #00 Phillips screwdriver.
  9. Osmo Mobile Charging Port Replacement: 手順 9、 1の画像 1
    • Hold down the larger of the two ribbon cables, and pull on circuit board with a constant and careful down and out motion.
  10. Osmo Mobile Charging Port Replacement: 手順 10、 1の画像 1
    • Remove the two screws from the green charging module and the two screws on the grey plate and remove from handle.
    • Replace charging module.
終わりに
作成者
3人の作成者と共同で作成されました。
William Tyler Wills
メンバー登録日: 09/28/17
426 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S2-G1, Nance Fall 2017 USF Tampa, Team S2-G1, Nance Fall 2017人のメンバー
USFT-NANCE-F17S2G1
4 メンバー
12のガイドは作成済み
3 件のコメント
Where can I buy a replacement port? Can’t find one with google.
patchdrury - 返信
Where can I buy the part. ?
John M O'Donovan - 返信
Which version Osmo Mobile is this for? I need one for ver. 3
Nick - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 35
今までの合計 2,746
