メインコンテンツにスキップ
Osmo Mobile Bluetooth Module Replacement
必要な工具と部品
  1. Osmo Mobile Bluetooth Module Replacement, Osmo Mobile Handle Disassembly: 手順 1、 2の画像 1 Osmo Mobile Bluetooth Module Replacement, Osmo Mobile Handle Disassembly: 手順 1、 2の画像 2
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
  2. Osmo Mobile Bluetooth Module Replacement: 手順 2、 2の画像 1 Osmo Mobile Bluetooth Module Replacement: 手順 2、 2の画像 2
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
  3. Osmo Mobile Bluetooth Module Replacement: 手順 3、 1の画像 1
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
  4. Osmo Mobile Bluetooth Module Replacement: 手順 4、 2の画像 1 Osmo Mobile Bluetooth Module Replacement: 手順 4、 2の画像 2
    • Remove joystick by gently pulling away from handle
  5. Osmo Mobile Bluetooth Module Replacement: 手順 5、 3の画像 1 Osmo Mobile Bluetooth Module Replacement: 手順 5、 3の画像 2 Osmo Mobile Bluetooth Module Replacement: 手順 5、 3の画像 3
    この手順で使用する道具:
    購入する
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
  6. Osmo Mobile Bluetooth Module Replacement: 手順 6、 3の画像 1 Osmo Mobile Bluetooth Module Replacement: 手順 6、 3の画像 2 Osmo Mobile Bluetooth Module Replacement: 手順 6、 3の画像 3
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
  7. Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: 手順 7、 3の画像 1 Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: 手順 7、 3の画像 2 Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: 手順 7、 3の画像 3
    • Locate and remove the black screw found at the base of the grey mounting plate.
    • Remove the grey face plate.
  8. Osmo Mobile Bluetooth Module Replacement: 手順 8、 2の画像 1 Osmo Mobile Bluetooth Module Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    購入する
    • Open the battery hatch and remove it by using the tweezers to press the hinge into the device.
    • Remove the black screw located underneath where the battery hatch was.
  9. Osmo Mobile Bluetooth Module Replacement: 手順 9、 2の画像 1 Osmo Mobile Bluetooth Module Replacement: 手順 9、 2の画像 2
    • Use the spudger to remove the front handle casing by sliding the spudger into the area between the handle grooves.
    • Slide the spudger around the groove to find the 6 clasps that hold the front part of the handle, and unclasp them.
    • Take off the front handle section to reveal the whole interior of the device.
  10. Osmo Mobile Bluetooth Module Replacement: 手順 10、 3の画像 1 Osmo Mobile Bluetooth Module Replacement: 手順 10、 3の画像 2 Osmo Mobile Bluetooth Module Replacement: 手順 10、 3の画像 3
    • Locate and remove the black screw in the center of the motherboard chip.
    • Remove motherboard and replace.
終わりに
作成者
4人の作成者と共同で作成されました。
William Tyler Wills
メンバー登録日: 09/28/17
426 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S2-G1, Nance Fall 2017 USF Tampa, Team S2-G1, Nance Fall 2017人のメンバー
USFT-NANCE-F17S2G1
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 1,633
