メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのXbox Controllerを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Original XBox Controller Teardown, Taking Off the Back Cover: 手順 1、 1の画像 1
    • The first thing you want to do is to turn over the XBox controller and locate the 4 screws on the back. Next you want to unscrew the screws and set them together off to the side.
  2. Original XBox Controller Teardown, What You Will See Inside: 手順 2、 1の画像 1
    • You will be looking at the controllers circuit board. There will be another screw in the middle of the board that you would want to take out as well. It's a different type of screw from the ones on the back cover, so separate that screw and the ones from the back cover.
  3. Original XBox Controller Teardown, What's in the Back: 手順 3、 1の画像 1
    • In the back, you will see the vibrator motors (Red) in the controller handles. You will also see the shoulder buttons (Blue) and the controllers central "Hub" where all the power is stored (Orange).
  4. Original XBox Controller Teardown, Reconstructing the Controller: 手順 4、 2の画像 1 Original XBox Controller Teardown, Reconstructing the Controller: 手順 4、 2の画像 2
    • After you are done looking around inside the XBox controller, you can start to put it back together.
    • Put the screw back in that you took out from the circuit board, and put back any buttons or anything else that you took out.
    • Then you want to put the back cover back on the controller and put the 4 screws back in.
    • And now your done!
作成者
3人の作成者と共同で作成されました。
R0B8I3 O
メンバー登録日: 04/19/18
168 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 67
今までの合計 4,178
