メインコンテンツにスキップ
Origin EON17-S mSATA SSDs Replacement
必要な工具と部品
  1. Origin EON17-S mSATA SSDs Replacement, mSATA SSDs: 手順 1、 1の画像 1
    • Opening your computer can be dangerous; give it at least 10 minutes to cool down after shutdown and ensure the power supply and battery are disconnected.
    • Disconnect all peripherals.
    • Disconnect the power cord.
    • Lay the computer upside-down.
  2. Origin EON17-S mSATA SSDs Replacement: 手順 2、 2の画像 1 Origin EON17-S mSATA SSDs Replacement: 手順 2、 2の画像 2
    • Push both locking tabs inward. One is spring loaded and will need to be held while removing the battery.
    • Remove the battery by pulling up on the tab.
    • To replace the drive in mSATA bay 1, continue to Step 3.
    • To replace the drive in mSATA bay 2, proceed to Step 7.
    • If you are unsure which drive you are replacing, follow all of the remaining steps.
  3. Origin EON17-S mSATA SSDs Replacement: 手順 3、 3の画像 1 Origin EON17-S mSATA SSDs Replacement: 手順 3、 3の画像 2 Origin EON17-S mSATA SSDs Replacement: 手順 3、 3の画像 3
    • Performing the following actions incorrectly can damage your hard drive and could result in lost data. Consider backing up your hard drive(s) before proceeding.
    • Remove the component cover by removing the six screws with a 3/32" screwdriver.
    • Remove the screws from the bottom of the computer.
    • Remove the screws from the back of the computer.
  4. Origin EON17-S mSATA SSDs Replacement: 手順 4、 1の画像 1
    • Remove the cover by gently pulling back and up.
  5. Origin EON17-S mSATA SSDs Replacement: 手順 5、 1の画像 1
    • An electrostatic discharge could damage your computer. Use an electrostatic wrist strap when working inside the computer.
    • Put on the electrostatic wrist strap and attach the alligator clip to a sturdy piece of metal inside the case.
  6. Origin EON17-S mSATA SSDs Replacement: 手順 6、 2の画像 1 Origin EON17-S mSATA SSDs Replacement: 手順 6、 2の画像 2
    • You will see the mSATA drive in the lower right hand corner of the component area.
    • Remove the screw on the far right side of the drive.
    • The drive will rise up to an angle.
    • Remove the drive by pulling in the direction the drive is positioned.
  7. Origin EON17-S mSATA SSDs Replacement: 手順 7、 2の画像 1 Origin EON17-S mSATA SSDs Replacement: 手順 7、 2の画像 2
    • Unscrew the two screws holding the hard drive cover to reveal the second mSATA bay.
    • There are two snaps on this cover, pull firmly but carefully to remove it without breaking them.
  8. Origin EON17-S mSATA SSDs Replacement: 手順 8、 2の画像 1 Origin EON17-S mSATA SSDs Replacement: 手順 8、 2の画像 2
    • Removing the hard drive is necessary to get to the second mSATA bay.
    • Remove the hard drive by sliding it towards you.
    • Once it is free of the port, use a screwdriver to gently pry it from the bay.
  9. Origin EON17-S mSATA SSDs Replacement: 手順 9、 1の画像 1
    • Remove the small, silver, rectangular plate below the hard drive bay.
    • Remove the small screw at the front of the plate.
    • Pull the plate up and out.
  10. Origin EON17-S mSATA SSDs Replacement: 手順 10、 2の画像 1 Origin EON17-S mSATA SSDs Replacement: 手順 10、 2の画像 2
    • Remove the small screw on the upper left of the hard drive.
    • The drive will rise up at an angle.
    • Remove the drive by pulling in the direction the drive is currently positioned.
終わりに
To reassemble your device, do anything you did in reverse.
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Caelan Langdon
メンバー登録日: 09/29/15
125 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 15-2, Green Fall 2015 Cal Poly, Team 15-2, Green Fall 2015人のメンバー
CPSU-GREEN-F15S15G2
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 20
今までの合計 3,756
