はじめに
Replacing the Focus Knob and adding a small amount of WD-40 are a few easy solutions for a Focus Knob that is jammed in place or ineffective.
必要な工具と部品
Hold Clock so the screen is facing away from you.
Using your thumbs, push up on battery cover to remove.
With your other hand, pull down on the A/C Adapter jack to remove.
Remove batteries by pushing a battery toward the spring.
Lift battery out at an angle. Repeat with second battery.
Use a Phillips #00 Screwdriver to remove the four (4) screws from the back of the projection arm.
Once screws are removed, lift the back up and off of the projection arm.
Turn the clock on its side. Slide the Focus Knob forward with your thumb.
The Focus Knob Component should now be free of Projection Arm.
Hold the Component in one hand and lift the Projection Beam up and away from the Focus Knob.
