メインコンテンツにスキップ
Oregon Scientific BAR339DP Light Projector Repurpose
必要な工具と部品
  1. Oregon Scientific BAR339DP Light Projector Repurpose, Light Projector Conversion: 手順 1、 1の画像 1
    • Instead of showing the clock/weather in the projection, you'll end up to see a large red disc.
    • This is going to REPLACE the existing functionality and is most likely not undoable.
    • Proceed at your own risk!
  2. Oregon Scientific BAR339DP Light Projector Repurpose, Remove the housing: 手順 2、 3の画像 1 Oregon Scientific BAR339DP Light Projector Repurpose, Remove the housing: 手順 2、 3の画像 2 Oregon Scientific BAR339DP Light Projector Repurpose, Remove the housing: 手順 2、 3の画像 3
    • Gently pry open the front case of the projector module.
    • Undo the 6 screws using a small Phillips screwdriver and remove the cover.
    • Pull on the projection assembly to detach it from the case. The top part, containing the lens is detachable by hand, the bottom one has 3 clips and a nut that secures it.
  3. Oregon Scientific BAR339DP Light Projector Repurpose, Disassemble the projector unit: 手順 3、 3の画像 1 Oregon Scientific BAR339DP Light Projector Repurpose, Disassemble the projector unit: 手順 3、 3の画像 2 Oregon Scientific BAR339DP Light Projector Repurpose, Disassemble the projector unit: 手順 3、 3の画像 3
    • Using a flat screwdriver/pryer press on the tabs on both sides of the assembly to make them loose.
    • Gently press on the upper piece of plastic, to the top.
    • Unscrew the large nut.
  4. Oregon Scientific BAR339DP Light Projector Repurpose, Decision time: 手順 4、 3の画像 1 Oregon Scientific BAR339DP Light Projector Repurpose, Decision time: 手順 4、 3の画像 2 Oregon Scientific BAR339DP Light Projector Repurpose, Decision time: 手順 4、 3の画像 3
    • After you disassemble the projector case, you can see the projector light, the passthrough display and the board that powers it.
    • You have 2 options:
    • Try to remove the connecting flex cable between the display and the board and replace it/repair it or clean the contacts on both ends. [I have tried this without success as the wires ripped off because they were aged]
    • Remove the display from the position (with or without removing the flex cable) and allow the projecting light to go through the lens directly - this way you obtain a big round red light: Mars on your wall!
  5. Oregon Scientific BAR339DP Light Projector Repurpose: 手順 5、 2の画像 1 Oregon Scientific BAR339DP Light Projector Repurpose: 手順 5、 2の画像 2
    • The red light is very bright, now it's time to reassemble the device in the reverse order!
    • In case you decided to remove the LCD screen, you should end up with a projection as seen in the picture taken in a dark room.
    • Enjoy your new ceiling light!
終わりに
作成者
2人の作成者と共同で作成されました。
bmdbest
メンバー登録日: 12/08/16
593 ポイント
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 15
今までの合計 457
