はじめに
Use this guide to replace the Projection Lamp on the Optoma HD72. A projection lamp is a very powerful bulb used to project images or a video. The projection lamp will need to be replaced if you are experiencing any of the following symptoms.
- Projection Lamp’s light is becoming dim
- The Lamp has burnt out completely
- A connection has become loose
A warning when replacing the bulb is to be wary of any electrostatic charge. Be sure to wear proper PPE i.e. rubber gloves, as well as ensure the device has been turned off for at least 5-10 minutes before disassembling.
必要な工具と部品
Use a Phillips screwdriver to loosen the single captive 2 mm screw that secures the small lamp panel on the lower case.
Remove the panel.
